Help with programmer
patrick911
Canada
Hi
I'm trying to program a site that has 12 LCN. LCN 8 and 9 does not have any frequency. I put 0 in the field of LCN 8 and 9 then I put the normal frequency to LCN 10-11-12. When I close the editor LCN 10-11 move to LCN 8-9 and LCN 12 move to LCN 10.
Now my question is what can I do to make sure LCN 8-9 stays clear and 10-11-12 stays at their place.
Thank you
mitaux8030
Silent Key
Home
Never had that situation before, but if you just put in dummy frequencies for the unassigned LCNs that should fix your problem.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
You don't have to enter dummy frequencies with ProGrammer. They can be skipped.
If there are ten active frequencies, enter all ten, in the correct order.
I've never had a problem and one system I listen to supposedly has three skipped channels.
I don't drop or miss calls.
Elroy
bar422
I had them same problem ......I put in the dummy frequencies and that cured it.
