Help with Proscan setup for broadcasting my scanner
bobruzzo
W1AV
Cranston, Rhode Island
I have registered version of Proscan and am a member of RR. I would like to be able to set up Proscan to use to broadcast the audio from scanner so I can hear it on my smartphone. I have no clue where to begin. I checked out Broadcastify but it looked way too time consuming. When you apply, you are supposed to enter ALL freqs and talkgroups you'll be streaming. I would have to type all the data manually and it would take all day. I monitor police, rescue, fire, some businesses, coast guard, airport, and railroads. I have been using "Zello" which sort of works OK. But that program is too quirky. I looked in Proscan and there are no clear simple instructions.
fxdscon
¯\_(ツ)_/¯
What scanner are you using to stream with?
fxdscon
¯\_(ツ)_/¯
Check the Proscan user manual... look in the "Web Server" section. Instructions are there for setting up the Proscan Web Server, and you can connect to it with your phone's web browser.
bobruzzo
W1AV
I am looking but dont see any instructions....just a few fields to fill in with stuff I dont know.
fxdscon
¯\_(ツ)_/¯
That's the web server itself, not the Proscan user manual.
bobruzzo
W1AV
Not going to work. I still need some kind of Broadcastify site to do this and I really dont have time tp manually type in 300+ freqs!
fxdscon
¯\_(ツ)_/¯
Not sure why it's not going to work for you... Proscan will do exactly what you are looking for, and it does it very nicely and easily.
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
Take the time to read through the manual, I control several of my radios through my phone's web browser seamlessly using Proscan. Best software to do it
belvdr
No longer interested in living
You can port forward your router to ProScan and listen wherever you want.
bobruzzo
W1AV
OK still confused. I thought you need some website to host your stream. I am trying to troubleshoot. I did get the server port to work 65535. The audio setup works....checked with loopback and I hear scanner audio thru speakers. I can START with no errors....thats as far as I got right now.
bobruzzo
W1AV
Why would you manually type the frequencies when you can easily import them via Proscan, you have a RR premium account
Sorry I just dont understand this part of it. What I meant by typing in all freqs manually, thats what Broadcastify wants you to do to sign up but apparently I DONT have to do that. So I dont understand why I need to import anything if I am just using scanner audio?
belvdr
ProScan has the website included. Port forward your router back to ProScan's web server port and you can listen anywhere you have data on your phone. You can also test on your LAN:
http://<IP of PC running ProScan>:65535
fxdscon
¯\_(ツ)_/¯
From the first line of the Web Server section in the Proscan Manual.....
Web Server
The Web Server is a server that doesn't require an external server.
bobruzzo
W1AV
I am not going to bother. I really dont want to go into router setup and risk messing up network cause I am totally not a network geek. I dont know how to do these things. I dont know what port forward is.
bobruzzo
W1AV
I tried this and it comes back "cant find site"
belvdr
You mentioned port 65535. Did you change that? If not, use port 5000:
http://<IP of PC running ProScan>:5000
