PSR-800: Help with restoring SD card and restore library
Austin, TX
#1
Hey, to all the PSR800 people, could someone possibly walk me through restoring a psr800.. I can't get anything to load.. it was errored out... I finally got it working but I need the copy of the sd card or something to load the info with zip code, etc.. I could call you or something.. it won't load the main library that allows you to type a city or zip code isn't loading..that part doesn't show up.. does anyone have a sequence list to restore it.. I'm on a win10 btw.
Harmon-K5HDM
Austin, TX
#3
Have you tried to "prepare memory card for first use" (can't remember the exact wording) from the EZScan software?
Sent from my SM-G930V using Tapatalk
Yes, I have the scanner working and I have been able to load some things into it.. what I am trying to do is restore the nationwide database list to the radio
Northern Ohio
#5
Try This -
1. In EazyScan click on Updates and select check for Library Update. If you don't have the latest then update EZScan with the latest.
2. After the update of library is finished it will ask you if you want to update the Scanner SD Card which you say yes to and also yes to Location.
You coluld also copy latest Library from EZScan by clicking on Scanner/SDCard on top of software and select Copy Library to Scanner SD CArd
That should do it.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
#6
Try This -
That should do it.
Kinda what I said too but this way you can select the option to format the entire microSD card.
