help
#1
hi im new to scanning and i purchased a bct15. as of right now this over my head. i understand it in general but i am not able to program it. can someone steer me in the right direction. do i need some sort if software or can i program it by hand. where do i start? thanks for the help!
Ames, IA
#2
Since you have the premium subscription I would download a copy of ARC15 from BuTel use the trial to get yourself up and running, If your lucky your computer will have a serial port so you can use the cable directly. If not get a USB to serial adapter.
http://www.butel.nl/
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
#3
CB60046, welcome to the forums. We have a wealth of topic specific forums. I would recommend reading over them all and their descriptions before posting next time. This would have been better suited in another forum. Thanks.
Moved to the Uniden forum.
