Help
braines
i need help in getting frequencies for the bloomington state police post on 800 mghz can anyone help
DiGiTaLD
http://www.radioreference.com/apps/db/?sid=933
Program the site(s) closest to you as a Motorola 800 MHz trunked system, then program the talkgroups you want to listen to. SAFE-T is a statewide trunked Motorola Smartzone Omnilink network, not standalone conventional channels at each post as was the case with low band.
smhamilt
Chesterton, IN
State Police - how do i program for them?
Im in porter county. Can anyone help with programming for these? Thanks
braines
I am aware of the Safe T system, I hear DOT fine but cannot receive State Police I have a pro 2033 scanner, I have entered the control channels in but have not received any STate police communication or IU PD or Monroe County traffic. what am I missing out of the equation
dwh367
Amateur Radio Operator
Owensboro, KY (Daviess County)
If you have a Pro-2033 then you're missing the whole 800MHz spectrum which means you won't hear the SAFE-T system. Even if you could, yours is a conventional scanner and won't trunk track. The coverage on your scanner stops at 512 MHz. You will need a newer digital trunk tracking scanner in order to listen to SAFE-T correctly.
braines
Mine is pro2055 I rechecked the model number it has trunk freq band in it, i hear state dot well and the police dispatches on mutual channels but nothing from the invidual police posts
AK9R
Staff member
Super Moderator
Central Indiana
The ISP talkgroups on SAFE-T are mostly digital. You will need a digital scanner to decode these transmissions.
The INDOT and Mutual Aid talkgroups are analog, that's why you are able to listen to them with your scanner.
