Help
ncsecurity
for some reason I cant hear anything with durham police? I could hear last night but now i cant....any info?
Richmond, VA
Are you hearing things other than Durham? For instance try listening to your nearest noaa weather frequency. This will help isolate if the problem is with the Durham system only or with your scanner/antenna as a whole.
Sent from my cm_tenderloin
ncsecurity
I can hear duke police but not durham....was'nt sure if they changed something in the last 12 hours
reconrider8
Eastern, NC
are you scanning in "Open" or "closed" mode? that may play a role not sure since i cant quite reach that far
ncsecurity
not sure i have a rs 433 scanner...i thought i knew about it but i must not.....they might have sitched to digital not sure....
ncsecurity
ok i'm picking up on other freqs not on primary or secondary channels...any ideas?
KE4ZNR
Radio Geek
Easy: We switched the Control Channel from 859.9625Mhz to
857.6875Mhz. Make the CC change and your radio will start following
the system again. :)
The four CCs in order on the system:
857.6875Mhz=CC 1
859.9625Mhz=CC 2
858.9625Mhz=CC 3
857.9625Mhz=CC 4
Marshall KE4ZNR
KE4ZNR
Radio Geek
The Durham system is a mixed analog and digital voice system but no changes were made as far as analog->digital.
The database is accurate as far as which users are analog and which
users are digital. Durham City Police are still using analog voice format.
Marshall KE4ZNR
