Help
chrisZent90
WV
I just got my scanner and I want to put p25 frequency on it but I don't know if it is a standard trunk or a one freq trunk. How can I find out? On radio reference
N9JIG
Sheriff
Moderator
Far NW Valley
If there are more than one frequency listed in Sites then it is likely a "Standard" system.
If it is listed as with the list of conventional frequencies but as P25 then it can be programmed either as One Frequency Trunked or as a conventional frequency.
tvengr
Well Known Member
Baltimore County, MD
I just got my scanner and I want to put p25 frequency on it Arebut I don't know if it is a standard trunk or a one freq trunk. How can I find out? On radio reference
The first thing I would do is check to see if it is in the Radio Reference database. What county are you in and what is it that you want to monitor? I will look it up for you. Are you using programming software?
W1KNE
PITA from New England
New England
What department and agency are you trying to monitor? We can help you out with this.
chrisZent90
WV
Police , sheriff, ems, state police and fire
I use free scan but to bull from the database fore the p25 you have to pay
US WV
hiegtx
Dallas, TX
US WV
Your screenshots are not clear in what you are trying to program. While you do need to be a Premium Subscriber for direct web import into FreeSCAN, ARCXT, or ProScan, FreeSCAN does have a function called EZ-Grab to pull information from a webpage & paste it into a programming file.
FreeScan User Guide - The RadioReference Wiki
See "Using EZ-Grab in the FreeSCAN User Guide.
The table settings for your statewide system are on the system's home page (that appears to be your second screenshot).
chrisZent90
WV
16328029148656579736035411971136.jpg16328029879736030297848772198387.jpg16328029148656579736035411971136.jpg
Can I use any of them
What about the input
tvengr
Well Known Member
Police, sheriff, EMS, state police, and fire in what county? They are all different. What is the frequency? We cannot help if you don't give us the needed information. Is it Kanawha County?
chrisZent90
WV
Yes
W1KNE
New England
So my suggestion to you is this. Shell out the money for the RR subscription. Using software such as ARC-XT or the like, download the DB into the software, delete what you don't want, and download into your scanner. All the settings (attenuator, digital thresholds, etc) will all be set for you, and you'll be good to go.
tvengr
Well Known Member
Are the conventional frequencies done and OK? Is it only Kanawha County on the WV SIRN system you need? I use ARC-XT for my programming.
wtp
Port Charlotte FL
chriszent90, i sent you a personal message on how to do it manually, if you have a minute to try it.
