TRX-1: Help
eyes00only
Denver Colorado
I haven't used my TRX1 for a long time but decided to program some businesses. When I try to scan it says there's nothing there (using Whistler software). I have the scanlist turned on. When I pick a tower on a system the frequencies show but when I do another system the previous one is gone. I used to be a whiz at this but I was younger. I know it's just a simple thing I'm doing wrong but can't figure it out.
tvengr
Well Known Member
Baltimore County, MD
You need to have everything in the programming file when you upload to the scanner. The file overwrites all of the scan lists. Anything not in the file will be deleted from the scanner. You cannot add one system or one scan list at a time.
IC-R20
LoBand Nation
Yeah do "Import From Scanner" first so it has everything that's on the scanner and you can work modifying things from there so you don't lose anything.
eyes00only
Denver Colorado
Thanks, seems to be working now.
