Henderson PD
MS1170
What radio's does henderson pd use? any chance they will be changing to 400mhz....seems to be a push in that direction
TOUGHLIFE
HPD is on the Clark County SNACC system which is a Motorola 800 MHz trunked system. It affords them easy mutual aid opportunities with many agencies except the LVMPD which is a bit more difficult to do but has been done in the past. You might visit AES and pick up a copy of the 2007 Southern Nevada Scanner Book which will enlighten you on monitoring in the greater Las Vegas area.
Back in 1998 HPD joined the SNACC system leaving their VHF system behind.
TOUGHLIFE
Aes
AES in case you are not aware of, is Amateur Electronics Supply located on Polaris, North of Tropicana in the SW LV area. They do carry the book that I mentioned and a lot of other radio accessories.
MS1170
radio
do you know what model motorola's they use? Thanks for the info..I don't live in vegas yet but plan on moving out there.
