hendry county
flip1335
hi new here was hoping to get some help with the local freqs and signal and 10-codes does anyone know or care to share some info id really appreciate it
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I'm going to have this moved to our Florida forum where Hendry County exists - there should be more folks there that can help you with this question...however you can check our database for frequency information yourself. Go to the upper left blue toolbar under the site title, float your mouse over Database then use the various pulldowns to get to your county. Our wiki doesn't have the local 10 codes; perhaps someone in the Florida forum does....best regards...Mike
loumaag
Silent Key - Aug 2014
Katy, TX
Moved as indicated by Mike.
Mike please check the report you submitted.
