Henry County LZ Ops
CommsMedic7184
If anybody could help, Im looking for the Henry County LZ Ops Rx freq to put in my scanner, I have everything else, thats the only channel I need
CommsMedic7184
Fire Ops is just used as a repeated tac channel for Structure Fires and MVCs. They have a separate channel now for that which is the one Im looking for.
BigLebowski
Piedmont NC
I have 155.670 $500 as "Safe Ops" (repeated) but my information is a little bit dated at this point. Not sure if they have made any major changes recently.
JamesMiracle
Stuart, VA
Fire ops and safe ops are still in use normally Lz ops is used for personal on the ground to communicate, on the ems channel is normally where they talk to air care patient info and landing info
JamesMiracle
Stuart, VA
So are Safe Ops and LZ Ops different then or is LZ Ops just simplex on 155.670 $500?
Henry county has 3 ops channels 4 if needed
Fire ops, Safe Comm/Ops (they call it safe comm), Lz ops and if needed they use Ad Comm
(Fire ops - 152.810 $500) (Safe Comm - 152.660 $500) (Ad Comm - 155.520 $500) (Lz Ops - 155.235 or 155.205 $500 or 114.8 ctss) with a lot of research on different websites you can find different things with what i listed was the same across multiple websites besides the Lz ops
JamesMiracle
Stuart, VA
JamesMiracle
Stuart, VA
I just found this too to back up my last 2 post about the Lz ops Common/Shared (Virginia) Scanner Frequencies and Radio Frequency Reference fire/ems statewide the description says EMS/Medevac Scene of Action Statewide and it’s tagged as EMS-Tac and in Civil Air Patrol (Virginia) Scanner Frequencies and Radio Frequency Reference they have the 155.205 description says On Scene/Landing Zone Common with the Alpha tag VA-EMS so I’m pretty confident that Lz ops is 155.205 with CSQ. next time they go to Lz ops I’ll put the frequency in and see if I can hear anything and I’ll post back when next time they go on LZ ops
JamesMiracle
Stuart, VA
This answers the OPs original question correctly.
These are also correct.
So lz ops is not 155.205? I know when u listen to fire dispatch and they request an ops channel they use fire ops, safe comm, ad comm and have lz ops
