HEX/DEC Programming?
TheFlyingPilot
MPSCS Newbie
Frankfort, Michigan
I'm using a BCD325P2 in Benzie County, MI. I looked around on RadioReference for new freqs I could put into my new scanner and I found some 800mhz channels, but I also found these HEX/DEC frequency-thingies (look below), and I can't figure out how to program them into my scanner. Anyone know how to do this?
Frequencies I found:
DEC/HEX
4201/1069
4335/10EF
4967/1367
5534/159E
5535/159F
5536/15A0
5537/15A1
N4ANJ
Rocky Mount, Va.
You don't need to program these. They are Talk Group ID's (TGID). They will come up on your scanner display when you program the site frequencies. You normally use the decimal TGID with a scanner. It sounds like this is your first time programming a P25 system. Good Luck.
Frankhappyg
Northeast,Ohio
In the Michigan's Public Safety Communications System (MPSCS) look for your county under the System Frequencies.
Looks like you have two site towers in your area.
Interlochen & Beulah (Honor).
Enter the red control and blue alternate channel.
Might look at your surrounding counties to as you might be able to pick them up also.
TheFlyingPilot
MPSCS Newbie
Frankfort, Michigan
Thanks! I've been looking around for a while now for these answers. I have been scanning with my BC75CLT for a few years now, but yeah, I'm just now getting into P25
