Hey Upman, 796d 3.29 download
KD8CES
Vermilion, OH
Hello, I tried to download the 3.29 update from the website but a message says it doesn't know what program to use to open the update, never had this problem before, can you help? will this download help to grab the signal a little better so I don't get that annoying warble noise just before the audio becomes readable? thanks in advance, scannerdweeb.
JoeyC
Senior Member
San Diego, CA
These downloads are zip files. You have to have an unzip program on your computer to open it. This is a common archive format and is not a Uniden problem.
KD8CES
Vermilion, OH
I did unzip the folder and read the install instructions but it said unable to open because windows does not know what program created file, then it tried to search online for the creator and unable to find. sd.
UPMan
In Memoriam
Arlington, TX
1. Unzip the files to a temporary directory.
2. Run "Setup.exe" from that directory.
3. After install, click on the BC_VUP icon on your desktop to run the update.
KD8CES
Vermilion, OH
ok, I performed steps above, but when I hit the bearclaw there is nothing there to run, it is empty, also when holding the l/o and 6 buttons when plugging in the a/c power nothing shows on the radio that I am in any other mode for programming, it stays in scan mode.
I have downloaded to this radio before with no problems. ?????? sd
KD8CES
Vermilion, OH
OK, I finally got the firmware loaded, don't ask what I did different, but it loaded succesfully. Now I noticed if I try to enter a freq by entering the digits directly and hitting enter, I get a message saying "enter lock" however the enter lock fuction in the menu is in the "off" position. the frequency can be entered ok going through the menu system. Don't know if during the power up and key holding for setup before downloading I pushed a wrong button, Is there some kind of reset procedure to perform. Scanner seems to be operating ok otherwise. thanks, Scannerdweeb.
KD8CES
Vermilion, OH
You are correct. Thank you for the expertise, where did you get the info though? I've never noticed that before. Thank you again, I should be set for awhile, maybe I can answer some questions for you someday. Scannerdweeb
JoeyC
Senior Member
San Diego, CA
I ran into the same problem waaay back when I got my 796 and somebody came to the rescue here.
chief371
bc796d
ive downloaded all the software and did everything possiable to upload new firmware and hit all the buttons 500 times now. any suggetions before i get my 9 mm out??
chief371
ive even unistalled the software and reinstalled and it automatic installs. also when it looks for the **SCN file there is not one.
chief371
this scanner is not a object for bc
rewritting is impossiable
please turn off power and remove the cable
KD8CES
Vermilion, OH
Those were the same incorrect instructions I was given several times, then one magical time the file opened and the instructions changed to the scan,l/o,6 command and everything went fine. I too, downloaded updates to this scanner before w/o all the problems this file gave me, corrupted????, Glitch?????? Did you notice any changes in performance on you scanner? Reception??? scannerdweeb.
chief371
very little ... but i was about to put a 9 mm into the from of the scanner let me tell ya.
Dubbin
Findlay Ohio
Well that sure would have gotten it to work... :lol:
