HF Amateur Radio Nets that I can monitor in S.E. Michigan?
iMONITOR
Silent Key
S.E. Michigan
I purchased a new Kenwood TS-590SG transceiver to be used as a receiver only until I get around to obtaining a license. Due to heath problem I'm able to install and outside antenna at this time. As a result I'm working with various minimum antennas inside my home. Are there any scheduled amateur radio nets I can monitor with this setup? I'm located in North Macomb County, Michigan. If you could please post their frequencies, days and times I should tune in it would be appreciated. I realize conditions are poor right now but I've been unable to fine anything.
Thanks,
Bill
jaspence
Michigan
An inside antenna is not likely to give you much success. Noise levels in some areas are high, and with an outside end fed antenna I sometimes cannot even get a good signal on 40 or 80 meters. Even WWV is not consistantly received. Don't forget that a good ground is also part of the antenna system.
a29zuk
SE Michigan
There is a Michigan net on 3935 most evenings around 2200 or 2300utc(6:00 or 7:00pm local). Also 3921 has a Michigan U.P. net around the same time on some weeknights.
Jim
Hit_Factor
Saint Joseph, MI
The Great Lakes Emergency & Traffic Net (GLETN) meets daily at 0200 UTC on 3.932 MHz.
The Michigan Emergency Net meets Sunday at 1400 UTC on 3.930 MHz.
The Michigan Wolverine Net meets daily pre-net at 2200 UTC Net at 2300 UTC on 3.935 MHz.
The Tuesday night Six-Meter Nets. SSB on 50.140 MHz. at 9:00 EST
Also Sunday Night Classic Round Table on 50.4 MHz. at 8:00 PM EST on AM
10-Meter SSB Net Wednesday, 9:00 (EST) on 28.485 MHz. NCS Phil, Kalamazoo
R0am3r
Salt Water Conch
Oneida County, NY
Depending on your noise level, give a listen to the following frequencies:
1930 KHz, Toad Harbor Net. Active some mornings and most evenings.
7163 KHz, The 7163 DX Net. Active from 09:00Z - 12:30Z.
7255 KHz, East Coast Amateur Radio Service (ECars). Active during the day.
7258 KHz, Midwest Amateur Radio Service (MidCars). Active during the day.
