HH Desktop Stand
N9JIG
Sheriff
Moderator
Far NW Valley
#1
I found this little business card holder at my local OfficeMax for about $10. It fits the 325 and the 436 like a glove! The radio stands straight up, will not fall over easily and the perforations do not block the sound. It has rubber feet so it doesn't scuff the desktop.
Here it is with a couple different radios:
03msc
Arkansas
#2
Nice find! I've also used the metal bookends (like the ones in the attached photo) to 'hang' a handheld on - even works for the 'nub' like on the 396XT from Uniden. You can also easily bend these to have the radio tilted back a little, if desired, and are usually wide enough for two handhelds. But great find on the business card holder, too!
Here's an example of what I was referring to...
