Amateur here! Getting ~8 SWR on following setup:
Surecom SW102 meter
Wouxun KG-1000G GMRS radio
EM Wave EM-M11001-195 5 dBi Ground Plane Independent Antenna 440-480
EM Wave EM-M11001-195 NMO Hole Mount Assembly with 17 ft. Low Loss 195 Cable
Mounting: Tube on rear tire carrier of 4x4. Not intentionally grounded since antenna is NGP type
TX test: 5w @ 462.6375 MHz (GMRS CH 4)
Antenna is near objects obviously, but that's the nature of a vehicle install. I'm otherwise testing outside my house. Not sure what I can adjust since the antenna data sheet insists tuning is not necessary for the intended frequency range.
Any suggestions? Thanks!
Surecom SW102 meter
