I installed a CB radio system in my Grand Cherokee and I'm getting high SWR readings, roughly 2.2 on channel 1 and 40.
OK, 2.2:1 SWR on channel 1 and 40, but what is the SWR on channel 19? Higher on channel 1 and 40 but low in the middle just means that the antenna has a very narrow bandwidth.
If it's pretty flat across all 40 channels, then there may be an issue.
I’ve read a variety of opinions regarding coax length and there doesn’t seem to be any concrete evidence to support a full 18 feet versus trimmed to the proper length
Use only the amount of cable you need to run from the radio to the antenna. The claims of "18 feet" are BS as it doesn't take into account the velocity of propagation of the cable. A properly installed and tuned antenna should not rely on specific cable length to give you low SWR.
Containment: I’ve been checking SWR in an open area...
An important point that many overlook.
...using the built in SWR meter.
Don't put all your faith on the built in meter. Check it against a known good meter. See if you can find someone local that has one, or invest in a separate meter if you are serious about this.
With antenna cap installed I calibrate then check SWR on channels 1 then 40 then adjust.
OK, but check on channel 19 also to develop a curve. Checking on the two ends doesn't give you all the info you need.
I’ve checked the coax for shorts and none exist.
Have you checked for opens?
I installed an additional wire from the mount to the chassis to make sure I’m getting good ground.
From the chassis or the body? DC ground and RF grounds are not the same. Use a short conductor from the mount to the vehicle body. Make sure you are getting a good connection. Scrape off paint if needed.
Side note: I made contact with someone 30 miles away and they reported a strong signal. It’s probably not relevant, but I was surprised and figured I’d mention it.
To me, that sounds pretty good, and makes me thing that maybe the built in SWR meter isn't as reliable as you'd expect it to be. Until you check all this against a known good meter, take the results of the built in meter with a grain of salt.
30 miles with a strong signal is pretty good for a stock(?) CB radio with a short antenna.
