Hillsborough County Sheriff Districts
David40
Florida
Does any know which of the four Sheriffs' districts covers the Eastern part of the county?
David40
Florida
Thanks for that info.
That being the case, looks like Plant City is completely in the NE District II. The lines on the map are not clearly defined. There is no color gradient between II and IV, and part of the line between I and II doesn't seem to follow any road at all, just drops off from from US301.
Anyway, I was mainly concerned with Plant City so that gives me what I need.
I appreciate it.
tampabaynews
Tampa, FL
I might add that the outskirts of Plant City is HCSO District II but the city has it's own police department. Forgive me if you already knew that.
