I have a hiss in the background on my SDS200 it ONLY is heard over my bluetooth adapter->bluetooth earpiece. I do NOT hear it from the internal speaker nor do I hear it with a single earphone plugged into the front speaker jack. The Bluetooth adapter is USB powered plugged into into the USB A port on the front and a jumper from the front speaker jack to the audio input of the Bluetooth adapter. The hiss sounds Iike an open squelch hiss but if I open the squelch, I get a much louder hiss that does change level with the volume control.. The hiss does not increase or decrease in volume via the audio level (volume) setting. The actual audio from the scanner does go up and down with the volume setting. It's a minor annoyance, not that big a deal.
I have done the "hum" fix by Static Discharge. Again, zero hiss (or hum) from an earphone or the internal speaker.
My obvious guess is that it is generated by the usb powered bluetooth adapter or the audio jumper cable having some kind of impedence mis-match.
Anyone have any ideas on what could be causing this?
