Home Command Post
tiawah466
CLAREMORE,OK
Here is my Home Command Post.
2 - Bearcat 780 XLT's One of these is dedicated to recording with the sound card.
Motorola HT 1550 XLS VHF
Radio Shack Pro-97
Mirage MP2 SWR/Power Meter
The Desktop has an Audigy2 ZS Sound Blaster Card. With this card I can go up to 7.1 digital speaker output. It has optical in and out, midi in out, digital in and out, plus a pc controlled mixer for everything.
The Laptop is the internet and other stuff computer.
k9-cop
On the middle screen it looks like a scanner, what software program is that and what does it control?
kma371
Thats Uniden 780 control software, can't remember who makes it.
tiawah466
CLAREMORE,OK
It is the 780 control software from Uniden. It is running the top 780, its screen is burned out and the only way to control it is by brail or computer. With this software you have vitural control over exery function on the radio except volume and squelch. The program is called WinScan 780 made by Pozilla.
k9-cop
So if you had the scanner in your garage and ran the computer interface cable into your home, you could see what freqency is being displayed on the scanner and all the other stuff right on your computer screen? You mentioned the volume can't be controlled through the software program but you could run an audio feed from the scanner to your computer right?
Also what kind of connection does it use to interface with the computer? Where can I download the software to check it out and see if this is a scanner that would work good for me?
motomeso
Ontario
tonsoffun said:
Nice set-up. What is the Motorola used for?
Take care
Looks like a UHF HT1550XLS with the antenna adapter for the in vehicle kit.
That you could, I even remote my BC796D from work using a virtual com port and Skype for the audio with no noticable delay.
Just a regular 9 pin serial cable and possibly a USB adapter if your computer doesn't have a serial port.
tiawah466
CLAREMORE,OK
I bought the software when I got my first 780. The scanner does connect with a regular serial, I have not had much luck using the usb adaptor with it. The scanner has 2 audio outputs, one speaker out, and one line level out for recording. As far as the HT 1550 XLS it is VHF and I us it for my FD, yes it does have the adaptor for the convertacom, see the link below. The motorola charger is for my Saber III VHF, which I usually keep at the station with my gear.
http://radioreference.com/forums/showthread.php?t=44135
motomeso
Ontario
Sorry my mistake, looking at the stubby antenna I thought it was a UHF but now I realize the VHF antenna off a HT-750 looks similar.
tiawah466
CLAREMORE,OK
I have had good performance out of the VHF stubby. I put in on when I added the adaptor, with a full size it looked goofy.
