I got a sds 100 & 200 and they both receive alot of LE traffic, dispatch for sure. Home patrol is nearly mute, had a couple random ems channels pop up but thats about it, while the 100 is blaring with police/fire activity. Am not much in the loop on technical terms, I generally now what you are referring to.What does the database say for what you would like to listen to for that area? If it says DE or TE it's full-time encrypted, De or Te for part-time encrypted. You said public safety so I am assuming police and fire, not aircraft or railroad etc. I looked at the state trunked system and quite a lot of law enforcement is part-time or full-time encrypted, but I see a lot of non encrypted talkgroups as well depending on where you are. Lot's of DMR and NXDN in the area for towns and cities in the state.
Advise which site you used when programming your HP-2, As Richard has noted, the HP-2 is not a great unit when dealing with simulcast sites.I got a sds 100 & 200 and they both receive alot of LE traffic, dispatch for sure. Home patrol is nearly mute, had a couple random ems channels pop up but thats about it, while the 100 is blaring with police/fire activity. Am not much in the loop on technical terms, I generally now what you are referring to.
I got the HP2 hoping to make it a garage scanner to listen to police/ems/fire mostly.
I’m in the Detroit area and use Unication G5 receivers or SDS100 for monitoring the area simulcast systems like Detroit. I Googled the question for a better technical description of the issues using a Home Patrol receiver for the Detroit Simulcast on MPSCS. Here’s what I found - The Uniden HomePatrol 2 struggles with simulcast systems due to its inability to effectively handle the signal overlap and interference inherent in these systems. Simulcast systems transmit the same signal from multiple towers simultaneously, which can cause signal overlap and distortion, particularly for scanners not specifically designed to filter and decode these complex signals, like the HomePatrol 2.I got a sds 100 & 200 and they both receive alot of LE traffic, dispatch for sure. Home patrol is nearly mute, had a couple random ems channels pop up but thats about it, while the 100 is blaring with police/fire activity. Am not much in the loop on technical terms, I generally now what you are referring to.
All LE/Emergecy services are enabled. NOAA comes in fine. No avoids/ATT, squelch is at 2, range is more than I need. using the stock antenna, but also with the SDS100, which receives fine.Check for any services enabled on your HP-2. Most of Wayne County is in the clear, so you should be getting plenty. Also, double-check you're receiving the local Detroit-area NOAA stations & Canadian weather services (from Windsor), to ensure the HP-2 is working fine. Also check for attenuation or avoids, and make sure squelch is set to 2. The HP-2 is pretty reliable, and you should be hearing things between both Detroit and Windsor quite well.
Wouldn't the signals be received then, but garbled ? Some of the few transmissions it has caught in fact were garbled, a few not.I’m in the Detroit area and use Unication G5 receivers or SDS100 for monitoring the area simulcast systems like Detroit. I Googled the question for a better technical description of the issues using a Home Patrol receiver for the Detroit Simulcast on MPSCS. Here’s what I found - The Uniden HomePatrol 2 struggles with simulcast systems due to its inability to effectively handle the signal overlap and interference inherent in these systems. Simulcast systems transmit the same signal from multiple towers simultaneously, which can cause signal overlap and distortion, particularly for scanners not specifically designed to filter and decode these complex signals, like the HomePatrol 2.
That's not always the case. When dealing with simulcast, you might get garbled transmissions, or nothing at all, depending on how many of the simulcast sites are hitting your scanner.Wouldn't the signals be received then, but garbled ? Some of the few transmissions it has caught in fact were garbled, a few not.
I’m not sure but I could speculate … the Detroit Simulcast has 11 towers. Mostly like you’re close to more than one of them since there are so many. It requires a clear signal from the control channel for the trunking receiver to work properly. It’s possible you hear nothing because the control channel reception is poor due to distortion caused by the multiple towers. See if it works with NO antenna. In my case, I live exactly 2.25 miles between 2 Detroit towers. One to the north and the other to the south. Sometimes I receive the Detroit system with no antenna on the SDS100.Wouldn't the signals be received then, but garbled ? Some of the few transmissions it has caught in fact were garbled, a few not.
