Home Patrol/Duluth
10-7Goodnight
I just picked up the Home Patrol. In scanning everything the last half hour, I'm not hearing anything from Duluth PD & Sheriff (155.595 & 155.415) I have not played with much yet, but it's frustrating. Somebody please at least tell me the basics. Is there a certain control channel I have to enter? I live right in town Duluth. Give me a call if you want. 218.310.9394 Thanks, Mike
jim47
MIssion, TX
You will not hear them on 155.595 and 155.415 anymore as St. Louis county has switched to the new ARMER system. I am not sure how you program the HomePatrol but I use RadioReference to program my BCD996XT and BCD396XT. I do hear them on the new ARMER system. Everything is in the 800 Mhz band now. You should listen to the Duluth Simulcast tower. The control channel is 856.46250 Mhz. Hope this helps.
JASII
Memory Capacity
Make sure that you have downlaoded the latest database AND run the Home Patrol HP-1 in the ID Search mode so that you get the new talkgroups as they pop up. Saint Louis County is a new enough user that not all of the talkgroups have been identified yet.
RickJF
Duluth, Mn
This should get you going if you just want the basics like you used to hear on the old 155.595 and 155.415.
Talk groups
37801 main Duluth police dispatch
37812 Duluth police info channel
37616 Duluth fire dept dispatch
39200 gold cross dispatch
37804 county squads dispatch
37802 county squads ch law 2
36500 mn state patrol dispatch
This list is not everything but you will have everything you had on the 2 channels you mentioned on your old scanner
jemcdlv
Duluth, MN
I also live in Duluth
I'm having the same problem, called RadioShack and they said it should work. I think I'm gonna try adding nearby communities like Lake, Hermantown, etc. and see if it comes up then. Otherwise, I don't have a clue. It's really frustrating, especially how expensive the scanner is!
n0elb
Duluth, MN
HomePatrol Duluth
jemcdlv -
I should be able to walk you through any issues you are having. I am also in Duluth and have the HomePatrol.
Send me an email and we can find a time to talk.
bholmen at pobox dot com
I don't notice my personal messages here on RR as easily.
Bruce
