HP-2: Home Patrol II error message
vegasjjimbo
Las Vegas
#1
SD file card
Remove battery & external power for 1 minute. If problem persists restore data using sentinel all clear.
Have done the above, unable to restore using sentinel all clear, as unit will not keep powered up.
Suggestions ?
Anne Arundel County, MD
#3
The high endurance cards cost about the same, and can handle more read/write transactions before they lose format. Uniden is now also recommending them because of problems people are having with the originals.
Sent from my LG-V410 using Tapatalk
