Home patrol serial port driver help !
eg153wftx
Mesa AZ
I purchased the Extreme Upgrade yesterday and installed on the home patrol....Since the Uniden web site is down AGAIN can someone please talk me step by step on how to download the serial port driver. I am using windows Vista. I have already download the zip files but I can not get it to install on this 'puter.
fxdscon
¯\_(ツ)_/¯
The Home Patrol web site works fine from here, here is a link to the Extreme Owners Manual:
http://info.uniden.com/twiki/pub/HomePatrol/WebHome/HomePatrol_OM_V2_Extreme.pdf
Serial driver instructions are on page 5.
dfw1417
DFW Texas
unzip the zip files to a folder. You will see only 2 files with .inf extensions. Copy the Vista/Win7 .inf extension to the C:\Windows\System32 directory. Now when you plug the HP into your computer choose the Serial instead of Mass Storage on the HP. Windows will open a window for the driver installation if necessary you can point it to C:\Windows\System32 but usually it is not required and the drivers automatically install ok.
Hope this helps.
Wayne.
JASII
Memory Capacity
Home Patrol Serial Port Driver Help!
I am having trouble with this, too. I downloaded the drivers, but when I try to un-zip them, I can't get it to work. Is there anybody that is able to e-mail the drivers to me without compressing them? I am using the Windows 7 Operating System.
KE4ZNR
Radio Geek
I just emailed the Win7 Driver to the email address you have listed here at RR.com.
Let me know if you don't receive it.
Marshall KE4ZNR
JASII
Memory Capacity
I did receive it and I have it in the computer, but I still can't connect to HP-1 for Virtual Control. It does the downloads fine in the Mass Storage mode, but no luck for the Serial Drivers!
Thank you for the file.
KE4ZNR
Radio Geek
What shows up in your Device Manager for Serial Port devices?
When you connect up the HP-1 and select the "Serial Mode" option instead of the "Mass Storage" mode what happens? It should ask you for a driver (if it does not see one) and then show up under the Device Manger.
Marshall KE4ZNR
freqhunter
Somewhere in Time....
I had issues with this as well. Windows did not prompt me to look for the driver. I had to tell it where to look. Once that was done it worked fine.
jkahn
Very good looking Member
Silver Spring MD
Window 8 and 8.1 need to be "fixed" in order to install an unsigned driver.
Even if you are not computer savvy, you can do this!
Just google "unsigned drivers". you should have many explanations that are essentially the same.
I would show you here, but I don't have one in front of me and I might miss a step.
JK ;-)
eg153wftx
Mesa AZ
O K I am going to the Uniden EX upgrade owners manual and going to page 5 the link to download the serial port driver is bad.... where can I go to download it... I have a new laptop since I asked this ? so I do not have the driver on this puter
RF23
Could you give us a bit more information about this problem?
Does the driver load?
Is it recognized by windows?
If yes to the above two, is the HP-1 recognized by the virtual control software?
You can have all the above working but the virtual control may not work. Some of the reasons are below?
You do know that only certain software applications will give you limited virtual control of the HP-1, like Butel's Arc Patrol however Uniden's software will not AFAIK.
The last time I used my HP-1 in virtual mode was in march and it worked via USB com4 from a USB 2.0 port however this time I had to try several different USB ports and finally found a USB 3.0 port that worked but it worked with USB com6. I have a lot of USB devices and apparently my ports are getting remapped for them, so you too may have to do some searching.
