Home Weather Stations
AC0RV
Park Hills, MO
I am looking into weather stations. I some recommendations on stations.
I await your response.
n5ims
As with most questions, some details of what you're looking for is required to provide you with a good answer. There are weather stations that are pretty cheap, but only provide indoor & outdoor temperature. Others cost a bit more and add humidity. They go up in price as you add features.
Some brands are :
Lacross Welcome to La Crosse Technology
Davis Quality wireless weather stations and software for home, education, and hobbyists by Davis
Oregon Scientific Oregon Scientific | U.S. | Store | Weather
Honeywell Honeywell Weather Stations
Others are also available, with several being clones of those above (e.g. "The Weather Channel" one is a rebranded Lacrosse.
mdulrich
Van Wert, Ohio
Unless you want to spend a LOT of money, I wouldn't look at anything but Davis. Anything cheaper is junk.
Mike
n5ims
Mike
Shouldn't that be IF you want to spend a lot of money get a Davis? They run $500 - $1000 (plus extras like software). I've used a Lacross (about $150 complete with software) for years without any issues (until lightning killed my rain sensor late early this year).
KE0SKN
KE0SKN - Member
Kasson, Minnesota
Well you can always use the cheapest methed. Tile a string to your door knob. Heres the rules
If string is:
Moving = Windy
Wet = Raining
Dry = Sunny
Missing= Tornado
lol good luke finding you weather station....lol
mdulrich
Van Wert, Ohio
Apparently you haven't priced systems used at airports and such.
Over the years I've used two Davis systems. The only reason I got the second was to go wireless at my new house and that was over eight years ago. I haven't had one problem with their systems.
Mike
WayneH
Forums Veteran
Super Moderator
Your master site
I use a wireless Davis Vantage Pro 2 with the serial port plug-in module. I run Davis' software and don't have any complaints. It has given me zero problems since I installed it last year. The forecasting is pretty useless though, which I'd figure would be normal.
AC0RV
Park Hills, MO
I am sorry not giving details. I did not know what to ask about
Basicilly
I want at least the following in a setup I can use
Tempature
Rain Gauge
Humidity
Barometer
Wind speed
and of course be wireless.
hope this helps
ShawnInPaso
Ditto on the Davis -
The setup you want (and more) comes with the Davis Vantage II. The lowest price I found was from "ProVantage". Mine was less than $400 delivered. It has been working great ever since - the wirelss option is far better than I expected.
HTH,
Shawn
Basicilly
Tempature
Rain Gauge
Humidity
Barometer
Wind speed
hope this helps
Brebuck
Elwood, IN
Davis products
Have used Vantage PRO 2 for 2 years with excellent results.
Provides max and min daily values for temp., dewpoint, pressure, rel. humidity, precip., max. rain rate, and peak gust and direction for 25 consecutive days.
W9NES
Indianapolis,Indiana
You can buy a Oregon Scientific Weather station at Radio Shack .I Bought mine there and have had no problems with it and it has everything on it that I need.It was on sale for $100.00.I know this is not a Davis but I do not have $500.00 to spend.
Brebuck
Elwood, IN
To Taloniilm
Your outdoors setup looks amazingly like mine except I have one antenna.
Just curious, what did you use to make the crossarms coming off the central mast (pole)?
Thanx
Bill R
psr600md
Green Bay,WI
If string is:
Moving = Windy
Wet = Raining
Dry = Sunny
Missing= Tornado
lol you forgot "stiff=cold"
Taloniilm
NE Texas
PVC to try to keep the weight down.
