Homebrew XTL rear prog cable?
tunnelmot
Conroe, TX
Anyone have a quick tutorial for homebrewing an XTL 5k rear USB programming cable from an accessory cable? I rolled my own XPR rear mobile prog cable with 0 issues a few years ago.
I know there are USB+/- pins on the rear connector. I would just like confirmation and where to source the additional pins needed. I just know I don't have to spend the $170 street price for one.
Wiscomm sells a kit for the XPR series kit with naked pins (which is how I built mine for 5 bux), but I cant find something similar for the XTL rear.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Thank you sir! Exactly what I needed.
Making such a USB programming cable is really easy, I made one for my XTL2500s. I just bought a used accessory plug off eBay ($10), and the connector pins from my local Moto shop. I used one of the many USB A to B cables I had lying around; cut off the B end, strip and tin the wires, and put on the crimp pins.
The most expensive single cost was the connector pins, 25 of them for about $30. On the other side of the coin, I only needed four of them (USB data + and data -, USB V+ and V-), the rest got saved for other projects, so my total cost was actually around $14.80 for the programming cable.
