hong kong gp380 problems
FIREPHIGHT
Illinois
the radio rx/tx just fine but has no display on the lcd screen but the backlight stays on all the time also the keypad does not make any noise when i press the keypad. this all started when i had the radio hooked to my computer for programing . help please
dixie729
Daviess Co., KY
Go back through the CPS programming. Sounds like the backlight was selected to "always on", and the keypad tones were turned off. Not really sure about the the "no display" on the lcd screen.
You should find the options in the utilities folder in the CPS.
w2smw
Town of Tonawanda NY
I had to replace the LCD display on mine a while back, it started to loose pixels and I finally had to replace it. Was it working before or did something happen while it was being used?
FIREPHIGHT
Illinois
it all happened while i had the rib cord hooked to it. I was programing it off of the computer and turned the radio off on accident while it was writing the radio when i turned it back on "nothing" no display just the green display and keypad stay on all the time. i have changed the backlight timer but it still stays on and i have programed the radio since and it takes
FIREPHIGHT
Illinois
update
ok so heres what i found out i opened up the radio and found that the flex keypad/controller pt # 8480475z03 was broke at where it bends and this caused the radio display back light to stay on all the time with no display
