Hoover Dam APCO 25
737mech
Clark County, NV.
#1
I have a psr 500 and I'm not sure if I programmed it correctly to monitor the Apco system. Is anyone having luck with auto p25 mode or should I use p25 manual and set the ch/hi and ch/lo / offset and step etc? What are they by the way? All the RRDB has is a freq. Need help please.
Redruth UK
#2
737 you might get more of a response re programming on the GRE section.I'm going to try & have set up the Uni 396 to be single freq ie no off set or other scanning setup.Good luck.
