Hot Glue Gun String
Matt93
Morris County, NJ
Okay, this has nothing to do with radios but has anyone ever used a hot glue gun before? Well, don't you hate when you pull the glue gun up from whatever you're gluing and a little glue string gets all over the place? Has anyone experienced this before or am I just imagining things. Thanks for your input!
fineshot1
NJ USA (Republic of NJ)
Yes - a real PITA.
I use some small cardboard strips to cutoff the string and then discard them.
Its not a perfect solution but it works and removes some of the PITA.
zz0468
175 DME, HEC 358° Radial
Funny... I was just using a hot glue gun tonight. Yep... lots of little glue strings. Annoying, but easy enough to clean up. And you can't beat hot glue for some jobs.
