In disassembling my scanner station's power cables so I could upgrade to a new PowerPole system I noticed that the fuse on the negative side of my power supply was very warm to the touch. When I removed the 30A fuse from the in-line fuse holder it was visibly cooked, the plastic was brown like cooked caramel on one side, although the fuse's link was intact. The rubber boot was partially melted.
The positive fuse on the red lead was fine and cool to the touch.
This had been in use for several years, it went from the power supply (currently a Samlex 30 amp) to a MFJ distribution block with 6 binder posts.
On my new set-up that I am still working on I will be using an MFJ-1128 PowerPole power block that includes a 40 amp main fuse and a dozen individually fused outlets. I will use some cable assemblies that have 4 coaxial power plugs each, to 5 amp fuses. Each of the 4-plug assemblies will power 3 scanners and an auxillary device such as a Stridsberg multicoupler or CSI tone decoder. The scanners are all current model Unide BCT15, BCT15X, BCD996XT, GRE PSR400, 410, or 600 type radios. There will be a total of 18 scanners, 4 decoders and 4 multicouplers. Total current draw is under 10 amps with all radios unsquelched at full volume so I don't think I am taxing the power supply too hard. It is usually left on 24/7 as 6 of the radios are used for data decoding and 5 are used for alert receivers.
(I have other radios but they are on other supplies.)
The questions here are:
1) Why was the negative lead's fuse so warm?
2) How can I prevent such a problem?
3) Should I even put a fuse on the negative lead? (I am not planning on it with the new install)
