Houston (TX) Fire & EMS Feed
Houston, TX
#1
With Hurricane Isaac's arrival, the Houston Fire & EMS feed was replaced by the Salt Grass Link amateur radio feed. Any idea on when the Houston Fire feed will return? Thanks!
mfn002
Bryan, Texas
#2
That happened to coincide with HFD's (brief) switchover to the Houston Public Works P25 Phase II system. They're back on UHF now, but I doubt the feed provider will continue with the HFD feed.
Houston,Tx.
#3
the feed will not return for HFD I don't have a scanner that will monitor them and since this is brief before they return to x2 or P2 I don't see a reason to have it up just for that short amount of time.
Houston, TX
#6
Bummer!
Thanks for all of the information. I guess time will tell if the HFD feed comes back. I really miss being able to hear what is going on in Houston!
Houston,Tx.
#7
Well you maybe in luch withh the new information in an email that I have gotten it says that we will be able to monitor them even with the HP-1 and others so if that happens and we should know befor the end of the year then I will put the feed back up for people to listen too including you. I just want to wait and make sure that we will be able to monitor them before i put it up so I don't have to bring it back down again.
Houston, TX
#8
More HFD Information
Yes, time will tell. There was an article in today's (9/16) Houston Chronicle about testing of the new digital system. It mentioned that scanners are not yet available. The new system is supposed to be in use by year end. I could not readily determine what will be done until the new system is fully up and running.
Houston, TX
#9
Houston (TX) Fire & EMS Feed Back!!
A big thanks to whomever got the HFD Fire & EMS scanner feed back on line. It is nice to have the dispatch channel back also. However, I do have a question. Is there a chance that channels TAC 7 and TAC 8 will be back? These are mainly used for fire calls and seem to be missing. Thanks!
