AR-DV10 How AOR Tried to Botch The Frequency Drift Hardware Design Fault
#63
One again this morning my ARDV10 was resetted at power ON sequence . Both VFO's were at 118.00 MHz . Sound and settings were also set to factory default. I saw that DMR decode is bad after this reset (drill effect ?)
#64
It VERY important you report this to AOR, multiple people also reported this. Only if more people report this there is hope that AOR will investigate and fix it. So far they have no clue whats wrong and considers it a extreme rare case. No matter how good or bad you english is, e-mail them!
