How can i reboot my Radio Shack PRO 197?
mcMechen,WV
Hello Everyone,
I need a little bit of help here. I would like some instructions on how to reboot my Radio Shack PRO 197?. Every time I go to push a button on it I get an error message. I would very much appreciate any help any of you could provide me with.
John
N8ZHF.
trp2525
Hello Everyone,
John
N8ZHF.
If you want to "Initialize the Scanner to Factory Defaults" (from pages 92-93 in the PRO-197 owner's manual) follow these steps:
Note: This procedure clears all information you stored in the
scanner’s working memory, AND resets the global parameters to
factory defaults. Initialize the scanner only when you are sure the
scanner is not working properly. V-Scanner memory is not affected
when the scanner is initialized.
1. Turn off the scanner, then turn it on again.
The scanner briefly displays the DSP boot version, and then the
Welcome/Owner screen is displayed.
2. Press 0 while the scanner is displaying the Welcome/Owner
screen.
3. Press 1.
4. Press ENT.
5. Press any key on the keypad to proceed.
6. Press any key on the keypad to proceed. The scanner will reboot
with file system and global parameters reset to factory defaults.
