How do Motorola scan lists work?
fonestar
Whitehorse, Yukon
Hi there... I have a PR1500 I am programming. I am used to programming Icom and Vertex HAM radios, so I am just learning the Motorla - CPS way of doing things as I go along.
My PR1500 has a total of 32 Channels available, currently 1 personality configured, 3 zones configured:
Zone 1: Higways and Business - Total 10 Channels
Zone 2: HAM Simplex & Repeaters - 10 Channels
Zone 3: Public Safety, Inter-Agency and Search and Rescue - 12 Channels
CPS will write the codeplug but the scan doesn't seem to work. As I understand it, I can have a total of 16 channels programmed in scan list? Is that 16 channels per list or 16 channels total for the radio? And those channels can be in different zones?
I'm sure it's something simple I am doing wrong. Thank-you...
Mr_Boh
The Land of Pleasant Living
Scan lists have to be assigned to the personalities. And you have to enable or disable scanning (or program a SCAN button) to enable or disable it. 16 per list on the scan.
Will001
SC
You have to go into every personality and enable the Scan List. I'm assuming you have a button enabled to start/stop the scanning function, so just make sure you enable scan on the personalities you want to scan.
fonestar
Whitehorse, Yukon
Yes I have the top button assigned to enable/disable scan. So I can have 3 Zones each scanning all of their channels?
But I need to have 3 personalities too? Do I understand this right?
Project25_MASTR
Millennial Graying OBT Guy
Texas
Bit of a mis-quote. With the Astro series portables and mobiles each individual personality would be assigned a scan list for scanning. With the Astro 25 series the personality was just a personality and not a traditionally defined "Mode".
If you only have one personality, add it to your scan list and then select the channels you wish to scan in the scan list settings. If you need another scan list, you will have to add another personality and add some of those previously assigned channels from personality to personality 2.
fonestar
Whitehorse, Yukon
So underneath Conventional Personality - Scan (tab) I can select None, 1, 2 or 3
I tried None and 1 for that personality... just tested Zone 1 and it doesn't appear to be scanning.
EDIT: Sorry, I forgot to add that I have also added another 2 personalities so I can have 3 separate scan lists.
Project25_MASTR
Texas
You also have to assign the channels in the scanlist menu under Scan in the main tree.
fonestar
Whitehorse, Yukon
Hi, yes okay I have done that for Scan list 1, 2 and 3.
But it still doesn't seem to be scanning? The radio did scan properly when I only had 16 channels in it and the A/B/C switch was set for PL Defeat/zone talk around/Scan .
Could there be something else I am missing?
fonestar
Whitehorse, Yukon
I don't know... I've tried everything I can think of. 3 personalities, 1 personality, same scan list programmed in multiple zones... this radio does not seem to scan.
crazyboy
NJ
It is most definitely a programming issue.
Set a button to select scan.
Under conventional personality, scan tab pick scan list 1.
Under Zone Channel Assignment 1, select personality 1 for each channel.
Under scan list 1, general tab scan list type conventional, priority one selected channel, priority 2 disabled, non priority operator select, designated voice tx selected channel, designated data none. Under the list tab of scan list 1 add the zone and channel of each channel you want to be scanned whenever you turn on scan from zone 1. Repeat steps for each zone if you want each zone to have a different list.
fonestar
Whitehorse, Yukon
Thank-you! Thank-you! Thank-you!
I was missing the parts about the designated tx and channel select under the scan configuration.
You guys make this the go-to site for HAM/2-Way, mobile, scanning, etc!
