I highly customize the programming of my scanners. I find EZ Scan to be anything but easy to use. I wonder what everyone else is doing.
Yeah that sounds a lot like how I program. I have a certain order to how channels are entered. County then city. Law enforcement, then fire, etc. I am finding a LOT of issues with EZ Scan. You can't "move" entries (other than trunk sites). When you enter TGs for a trunked site, it sorts them in TG order (YUCK). I don't see a way to copy what is programmed (even to the clipboard) so I can build another profile from what I've already done. I see no way to change the defaults (such as delay on with 3.0 seconds instead of off with 2.0 seconds). I mean the list is LOOONNNNGGG.gmclam - I Program my Pro-668 by County then by City. I have a Playlist for Each county in my 9 County Region in SF Bay area.
we have Several Multi-County Systems in Operation some use Analog and Others use P25 Phase I.
You need to break your old habits of other software, once you open your mind to the way ezscan works you will see it really is EASY.Yeah that sounds a lot like how I program. I have a certain order to how channels are entered. County then city. Law enforcement, then fire, etc. I am finding a LOT of issues with EZ Scan. You can't "move" entries (other than trunk sites). When you enter TGs for a trunked site, it sorts them in TG order (YUCK). I don't see a way to copy what is programmed (even to the clipboard) so I can build another profile from what I've already done. I see no way to change the defaults (such as delay on with 3.0 seconds instead of off with 2.0 seconds). I mean the list is LOOONNNNGGG.
What I see is that EZ Scan provides a means for people to obtain the RR DB and get it into the scanner. Further selection is done by zip code or some personal choices that were very simple. I have to wonder how many people steered away from these models because of this huge oversight (not to mention that downloading the software from their site is "browser limited").
It is easy if you are importing from RR. Not easy to customize, which is the entire purpose.You need to break your old habits of other software, once you open your mind to the way ezscan works you will see it really is EASY.
I am using all of Don Starr's software (WINxxx) and a few others (FreeScan, etc); they have the ability to import from RR and then export as I see fit. OK, so you can't export to the clipboard, you need to be able to "copy" a "system" from one profile into another.No you cannot copy anything in ezscan and that is due to the licensing agreement with this website. SO set everything up in a spread sheet like excel or openoffice(free) then you can copy and paste that data into ANY scanner programming software.
When I say move, I mean change the order of the channels or talkgroups. I can't be limited to sorted by TG value. Crazy.You can move anything, simply by going to the column that says Scanlist and unchecking the current scanlist, then checking off the list you want to move it to.
Unfortunately I expect that people who don't use the so-called preferred method must either do it this way or use other software. For my trial run I was copying from WIN500 to EZS via the clipboard, but that still leaves a lot of stuff that doesn't get set. I too was using the Excel method to get from different generations of scanners, but their software has full copy & paste functions. ThanksExcel to CSV to EZScan for the Conventional stuff. EZScan imported from RR for the trunked systems. It's my primary mobile rig, and I travel all over California for pleasure and occasionally public safety. So I have very customized scanlists based on both geographic boundaries as well as agencies and disciplines. I went to Excel and manual entry after a year because EZScan can't do the heavy lifting of 2000+ channels in nearly 200 scanlists that I need.
My understanding is that these scanners do not scan talkgroups. They sit on the control channel and look for channel grants to compare to talkgroups programmed and enabled. So order wouldn't matter on TSYS objects, just on conventionals, which can be put in whatever order you choose. Correct me if I'm wrong please, I am not trying to be a smart-aleck here, just better understand your situation.It is easy if you are importing from RR. Not easy to customize, which is the entire purpose.
You are entirely correct. The point of organizing stuff has NOTHING to do with trying to tell the scanner how to scan. It has everything to do with (manually) finding what you want to hear.My understanding is that these scanners do not scan talkgroups. They sit on the control channel and look for channel grants to compare to talkgroups programmed and enabled. So order wouldn't matter on TSYS objects, just on conventionals, which can be put in whatever order you choose. Correct me if I'm wrong please, I am not trying to be a smart-aleck here, just better understand your situation.
OK I understand your concerns now. I handle this by using multiple scan lists so that things become manageable when I need to drill down on a certain TG. It works for me, but as with everything, YMMV. E-Z Scan isn't perfect, but it does come included without having to be purchased separately and doesn't require the premium subscription to import...I guess to my mind that forgives some lack of functionality.You are entirely correct. The point of organizing stuff has NOTHING to do with trying to tell the scanner how to scan. It has everything to do with (manually) finding what you want to hear.
Consider that you're out somewhere, not at a computer, and an incident happens. Everyone switches to a specific channel or TG by name. I can presently get there on my scanners because I know how things are ordered. Can't do that if software does what it wants.
LOLOrder is for those with OCD , start each alpha tag with a number, then they will be in order
Not for advanced scanning techniques with California Highway Patrol and their split base/mobile TX.Order is for those with OCD , start each alpha tag with a number, then they will be in order
