How does a GMRS repeater extend the transmit of of a mobile?
mwvernon
I am looking into building a portable GMRS repeater. My question is that if my 5 watt UHF radio isnt powerful enough to transmit to the secondary radio how will a repeater help? Isn't a repeater limited by how far the handheld can transmit?
Rt169Radio
CT
If a radio transmit signal (say from a handheld) can reach the repeater,the repeater rebroadcasts that signal again on a higher transmit power.
mwvernon
So then that means if you only have a 5 watt handheld does it make sense to have a 50 watt repeater?
mwvernon
Maybe if i explain my situation you will be able to help better.
I have (6) 4 Watt i believe GMRS radios that friends and i have for community service events we help out with. We all have our GRMS licenses from the FCC. I am looking to build a portable repeater system to extend the transmit and receive distance. Does it make sense for me to spend the extra money on a 50 watt repeater if only after say 2 miles it will become a 1 way communication device?
I understand that if person A is standing near the repeater person B will be able to hear him. But if person B is 3 miles away he cant talk back. Correct?
Let say you and a friend are out in the woods. You can reliably communicate using your own voices and ears up to 200 feet apart. That would be similar to how simplex radio works. Your radio can only transmit so far to the other radio.
Now, bring in a third friend. Have him stand where friend 2 was, and now have friend two walk another 200 feet away. You can now talk to friend 3, 200 feet away from you, and he, in turn, can talk to the other friend who is now a total of 400 feet from you.
Now put said friend on a mountain top with a hearing aid and a mega phone. Sorta a simple explanation about how a repeater works.
The limitations of your mobile or handheld radio are:
Limited transit power.
Limited gan antenna.
Limited range due to topographical shielding (fancy way of saying "there is a dang mountain in my way)
While it may be difficult to talk to a radio 5 miles away due to the above limitations, it is a lot easier for your radio to be heard from a mountain top, from the top of a tall building, or the top of a tall tower.
The repeater can run a larger antenna with more gain (able to hear quieter signals)
The repeater can run more power (Can yell louder)
The repeater is on top of a hill, so it can "see" over the mountain that is in your way. (can yell around corners)
The repeater also breaks down at the least opportune time, usually in the rain or snow, and almost always in the middle of the night. You will rarely have the correct part in your truck, but that's a discussion for another time...
