How is this Wah-Wah made?
#2
Are you talking about the Wah-Wah sound at the beginning of the song (and repeated a few times throughout)?
There is a device that guitarists use (I"ve been one for 40yrs) called a wah pedal. It is a fairly simple device. It is essentially a tone control but instead of a rotating knob, the pedal is moved much like a gas pedal in a car: more gas = higher frequencies are accentuated. Less gas = higher frequencies are reduced. The effect can also be produced without a "pedal". The rate and intensity of the effect (change of tone from low to high) can be controlled eleectronically.
You can probably Youtube wah wah effects pedals to get a better understanding. I hope this answers your question.
Bryn-Mawr/Skyway Area
#3
That's what I thought it was given the constant chord changes. I know there's a ton of ways to make wah wah so wasn't sure and just recently started listening to stuff from my library and felt curiousity arousing again.
