daysand
How should I attach the Aluminum Grounding Wire on to my Radio Shack,
Outdoor Scanner Antenna?
I know Grounding Wire attached to the Grounding Rod is for Lighting Protection.
I was going to put the Grounding Wire between the Antenna's Base Plate the Mast and Just then tighten the U bolt.
Is there any other way I should do this?
Also does the Aluminum Grounding Wire improve the Reception?
