How to change to blue display on BCD536HP?
Grand Rapids, Michigan
#1
I am seeing a lot of screenshots of the display on the BCD536HP where the display is blue.
How do I change the background display color for the white to blue, or is this even possible?
Thanks!
PA
#2
You would have to disassemble the scanner and replace the SMD display backlight LEDs with LEDs of a different color. It can be done, but don't try it unless you have advanced-level skills soldering extremely tiny devices.
werinshades
Chicago , IL
#5
I just sent an older 536hp in with the fading blue light, but my newer one has the white display which I like better. I'm hoping that the fading blue display will be replaced with a white despite I didn't make that specific request or they no longer use the blue back light? White is much easier to see..
werinshades
Chicago , IL
#6
I contacted Uniden Repair today. This isn't white, but Cyan, which the repaired unit will be replaced with. I wouldn't recommend blue.
