How To Clean Scanner Case?
ronmicha
memphis, tn
What would you recommend to clean and shine a pocket scanner plastic case. I have the Radio Shack Pro-39 which I don't use much but after Katrina I plan on getting it cleaned up, programmed correctly, and storing it in my emergency bag. I don't like Fantastic. It's too sticky. I could wax it with Pledge. But it needs cleaning first with a Q-Tip and some substance.
Thanks.
Ron
flyingwolf
Old School
Northern Kentucky
little bit of soap and water.
Since that scanenr is far beyond the warrenty period I would recomend (if you feel like your able) to remove the two halves of the case and wash them with a mild soap and water.
Simply use your hands as the cleaning frush
Or you can use a soft nail brush to get al the little areas.
Then of course let it dry COMPLETELY.
And you should eb good to go..
TO keep it looking nice I like Maguires quick wax.
Its a spray on that works nicely. And wont damage the plastic.
Aslo works great for clearing up small scratches in eyeglasses.
Zonko
Depending on how badly encrusted with dirt, I would either agree with the above Gentleman (or woman), or, if it's really bad, a bit of white spirit.
MacombMonitor
I've had very good results with lightly dampening some paper towel with Windex window cleaner, then wiping the radio with that. However, be careful, as it could cause labels, and letters, to rub off, if used too agressively. I've never had a problem using it on radios, or computer equipment.
jmp883
Northern NJ
Armor-All Cleaner works well, again being careful around lettering. If you wanted your radio to look really good you could also use Armor-All Protectant but it would probably make your unit slip right out of your hand......and I just hate it when my unit slips out of my hand! :wink:
45-70-405
Napa, CA
Simple Green works well to clean things up. That is what I use in my shop.
Josh
flyingwolf
Old School
Northern Kentucky
jmp883 said:
.....but it would probably make your unit slip right out of your hand......and I just hate it when my unit slips out of my hand! :wink:
Groan.
But now you owe me a keyboard. I spit Kool-Aid all over it.
Buckskinner33
Wichita Kansas
Just how many times does your unit slip out of your hands?.... It must not be that Big of a deal for you If you keep doing it!!!! (Dont be mad....You left yourself wide open for this)
If your clear plastic screen is scrathed up use tooth paste to get rid of the scratches...Dont beleave me...Try it out first on a scratched up CD....
DPD1
There's also this liquid stuff you can get at hobby stores for polishing clear model parts, like airplane canopies and things like that. If the scratch is really deep, you can also get a special sanding stick that is made for the same thing. It has three steps of grit, and you work your way up with each one, then use the liquid polish last.
Dave
-DPD Productions - Custom Scanner, MURS, & Ham Antennas-
http://eje.railfan.net/dpdp/
jmp883
Northern NJ
To Flyingwolf,
Better to have spit Kool-Aid on your keyboard than on your monitor. Keyboards are a lot cheaper to replace!
To Buckskinner33,
You're right, I absolutely left myself open. There's nothing wrong with that, I've nothing to hide. Now, what's with your avatar? An overweight Barney The Dinosaur? And after watching him for a few seconds it looks like he's sufferning from 'unit slip' as well! :roll:
Now, let's keep this family-oriented......:roll: !
Buckskinner33
Wichita Kansas
jmp883 said:
To Flyingwolf,
To Buckskinner33,
;) Ive had a lot of request about him lately.... This is KOZO, He likes Amour All too! And he's a pretty smooth dancer and a mean Sumo Wrestler!
You want to watch him dance go here: http://www.milkandcookies.com/links/7675/
