PL tones (generically referred to as Continuous Tone Controlled Squelch System – CTCSS) and Digital PL codes (generically referred to as Digital Tone Control System – DTCS) are encoded with the voice audio at all times during transmission, and are used to control repeaters, exclude unwanted or uninvited traffic throughout the Public Safety, business, amateur and GMRS two-way world.
A PL tone is a sub audible tone in the range of 67 to 254 Hz. The FM deviation level of CTCSS tones should be in the range of 500 to 800 Hz. Any one or more of the 50 tones can be utilized by the communications system.
A Digital PL code is digital data or code word, expressed as a three digit octal number, that is transmitted with the voice audio. Unlike CTCSS (Continuous Tone Coded Squelch System) which uses continuous tones below 300 Hz, DCS uses digital data or code words. Each code word is unique and all code words may be used on the same channel without interference.
It is extremely important to use the exact PL tone or DPL code, otherwise other users on your radio network will not hear your transmissions.
Communications planners decide ahead of time how they can minimize interference between multiple users on a single channel, or multiple radio systems assigned to the same frequency. Using PL tones and DPL codes is an effective way to minimize unwanted interference.
Here are the PL tones:
67.0 69.3 71.9 74.4 77.0
79.7 82.5 85.4 88.5 91.5
94.8 97.4 100.0 103.5 107.2
110.9 114.8 118.8 123.0 127.3
131.8 136.5 141.3 146.2 151.4
156.7 162.2 167.9 173.8 179.9
186.2 192.8 203.5 206.5 210.7
218.1 225.7 229.1 233.6 241.8
250.3 254.1
Here are the DPL tones:
023 114 205 306 411 503 606 703
025 115 223 311 412 506 612 712
026 116 226 315 413 516 624 723
031 125 243 331 423 532 627 731
032 131 244 343 431 546 631 732
043 132 245 345 432 565 632 734
047 134 251 351 445 654 743
051 143 261 364 464 662 754
054 152 263 365 465 664
065 155 265 371 466
071 156 271
072 162
073 165
074 172
174
