How to get Live audio feed to play using winamp
Brandontb85
Weaverville NC
Hi I need some help to get live audio feed to play using winamp. everything i try i cant get it to work. all the help i can get i will appreciate.
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
Are you getting an error message, or has the feed stopped loading ?
Keep in mind that connecting to a feed might be impacted if the feed originates in an area experiencing severe weather and a related power outage, or if the feed has been inundated by online listeners.
KE4ZNR
KE4ZNR@radioreference.com
Brandon,
In addition to what Jeff shares above try one of the other players as well (like the web
player). That way you can tell if it is a stream/audio feed issue or a player issue.
Marshall KE4ZNR
