i have a bcd996t scanner and i am using a radio shack scanner antenna (20-176) mounted outside.
i live in a metro area where there are all types of communications are being used.
when i am scanning the railroad band. i am receiving some type of interference. the interference sounds like a pager tone followed by a humming noise or morse code.
i am also having another problem. i was listing to a railroad dispatcher 161.460 when the local pd 155.070 broadcasted. as a result i heard the railroad dispatcher, the pd dispatcher, and the local noaa weather band all n the 161.460 channel.
i have not use attenuator setting in he scanner. if i do so will it reduce the reception range of the channels in the scanner.
i addition the bcd996t scanner has a range setting which is graduated in miles like 10, 20, and so on.
what does this setting do and if in increase the range from 10 to 20 will it make a difference in reception.
