How to get the most benefit of a dual band dual receive radio?
timo123451
west des moines
#1
I just setup my Kenwood TM-D710A . I have programmed all of my frequencies into the memory channels. I'm curious as to how most people use this radio to get the most benefit of the dual receive? Does it make sense to have vhf on one side and uhf on another? Should I just use one side to monitor a favorite frequency and one side to scan all of my frequencies? Any suggestions? Thanks.
n9mxq
Belvidere IL
#2
Basically play with it and see what you like. Most 710 users have one side set to APRS so we can't use both sides to scan.
No bits were harmed in the posting of this message.
Oklahoma
#3
Both ways of using each 'side' of that radio will work just fine. Which would be the most usable/beneficial to you?
- 'Doc
krokus
Southeastern Michigan
#7
Like others have said, find what works best for you. Sometimes I use both sides for 2m, sometimes I might use x-band repeat, and monitor public safety VHF while on 2m. Whatever is useful at the time.
Sent from Tapatalk
