How to identify encrypted files on an LPE-200
GILMOORE
Can someone please explain how to identify encrypted files on an LPE-200? Do you need to be in program mode to find that type of file? Or can you manually go through the radio and identify the encrypted files? Thanks in advance.
GILMOORE
No answers? Come on guys, you must have an answer on how to identify the file. Is it all numbers or letters? I'm not looking for sound, I can identify the sound of it.
GILMOORE
JungleJim said:
what do you mean by encrypted files. feature encryption? ESK? Voice encryption?
Voice encryption. I know what the voice encryption sounds like, but I want to identify the frequency. Does it start with letters and numbers, how long would it be, how many letters and numbers? Because I have an LPE-200 that's being worked on at the moment, and it's missing that type of file.
rmiles
Bel Air, MD
Let's not confuse voice encryption with feature encryption. That's why I asked you to call me. Voice encryption is ILLEGAL to monitor unless you have authorization (i.e., you're an approved system user). What you want is the FEATURE ENCRYPTION file (.ENC) to restore the FEATURE ENCRYPTION on your LPE that I have.
The features in you radio are keyed to the radios ROM serial number. That's the encryption part. M/A-Com applies some sort of algorithm to the mix that gives you a hexadecimal string of 16 characters. Somehow, yours got deleted. I've been trying to contact you by phone to get a better picture of what happened to the radio. The file should be stored on your computer under;
C:\Program Files\MA-COM Software Tools\ProGrammer\backup
and will be your radios ROM S/N .ENC The file directory may be a bit different, depending on which version of ProGrammer you're using.
This posting will give you a good working understanding of what Feature Encryption is, and what it does.
http://www.radioreference.com/forums/showthread.php?t=2325&highlight=feature+encryption
rescue161
KE4FHH
Hubert, NC
The frequency has nothing to do with the Feature Encryption. Feature Encryption is modified to enable or disable features on the radio. If you want to modify the frequencies, you have to modify them via ProGrammer. It looks like you tried to edit the Feature Encryption and ended up changing it, therefore rendering your radio useless. You should NEVER play around with Radio Maint...
GILMOORE
Thanks for all your replies. You guys are great help. That explains it all. Thanks again.
FiremanSparky
Somewhere in the Rocky Mountains
Hello rmiles
Not to hijack the thread, but is this something that the programmer does automatically when you program the radio (in this case, the LPE-200) or is this something that should be done prior to programming it? For example, using the software, the user would back up his files MANUALLY and saving them prior to programming as compared to the software AUTOMATICALLY saving the file.
Thanks,
Frank
rmiles
Bel Air, MD
FiremanSparky said:
Hello rmiles
Thanks,
Frank
BOTH! The very first thing you should do when you get a "new" GE/Ericsson/Ma-Com radio is save the four files (.TRK, .ENC, .BIZ/BIS & .DSP/ADI) to your computer. But when you read the radio with ProGrammer, it automatically saves the feature string and I think the tracking data. That way, if you delete it, you still have a back up.
