How to lock out an ID in an pro- 106
tvengr
Well Known Member
Baltimore County, MD
While stopped on the ID, press L/OUT. That is a temporary lockout. The lockout will be cleared when you turn off the scanner. For a permanent lockout, press FUNC and then L/OUT.
tvengr
Well Known Member
You can press PAUSE or MAN. If in MAN, you can select the scan list using the left and right arrows and scroll to the ID using the up and down arrows. You don't have to wait for the ID to be active when using MAN.
gmclam
Fair Oaks, CA
Are you trying to lock out a conventional frequency, talk group or talk group when using a wild card in a trunked system? There are some slight differences. Generally speaking you can navigate manually to the CONV or TGRP object and lock it out using one of the two methods (L/O or FUNC L/O).
