I just got my GPS puck wired up. The GPS acquires within a few seconds. The SDS100 'GPS' indicator doesn't display for close to 2 minutes after inserting the plug into the USB port of the SDS100.
Then, I enter ZIP code 90210, it loads the California database and starts scanning LA County stuff. Even though the GPS indicator is on the SDS100 does not immediately switch to the local freqs (where the GPS is located.). Again, it'll take around 2 minutes for the SDS100 to recognize the GPS and then it'll reload the national database for the local area and start scanning.
If I disable the full database, unplug the GPS, enter a ZIP code for a 100 miles away the SDS100 will, of course, load and scan the correct freqs. Then I plug the GPS in and once the SDS100 reads the GPS data it'll change to the local freqs.
So, I suppose it works but the SDS100 takes longer than the 436 and 536 to read the GPS data.
I've never traveled with the Full Database enabled using a GPS. Is this how it's supposed to work? It reloads the appropriate states as you move down the road?
And, is the GPS data read time by design supposed to be close to 2 minutes?
