I'm in your area and can do Motorola NAS programming, but I won't even touch radios that old. Check fleabay for an XTL2500 or XTL5000 in the 700/800 band and I could throw the Philly TRS in it. Delco is still analog UHF T-Band for the moment, but all other counties in the area are using 700 MHz P25 Phase 2 systems, which in the Motorola realm is limited to the APX series (APX4500, 6500, 7500, 8500). Unless you just want some analog dispatch channels, etc, then you can get an appropriate band XTL and I could throw those in. The XTL mobiles are dirt cheap (under $100) but the APX mobiles are going to be upwards of $1,000.
