How to program " Key Up tone when someone keys up"
SFD790
Seneca, SC
Hi, wondering how to program my CP200XLS to " Key Up when someone talks". Also, c an somebody explain the Quick-Call II where you can program multipule Tone sets, not confusing the Quick Call System II. I can program as many tones as I want, and select a channel to store it on. Does this mean I can program (EX. 21 Tone Sets on 1 Channel?) thanks mike,
gtaman
TACSAT
GALAXY 19 91.0° W
The key up tone is usually only for when you use mdc1200 on a personality set mdc 1200 and set the pre setting and set everything at the lowest setting where the annoying "squak" is minimal.
With quick call II you only can set up a few sets of tones. You can have different sets per a channel but only 5 or 4 quick call systems. Each channel will only get one set. Not multiple quick call systems.
SFD790
Seneca, SC
ok, If I go under Signaling, to Quick Call II Systems, I have the option for four (4) Quick Call System channel available. If I go down to Quick Call II, I have the option to put as many Tone Sets as I want, but after that it says Choose Quick Call II System, and I have to choose 1 of the 4 Systems, Then I have to Choose a Reverse Personality, which is a Channel in my radio.
My Main Channel is what our fire dispatch, tones us out on. Can I program all these tones in the Quick Call II, and assign those tones to the same channel?
Example:
If I programmed the following Tones into the Quick Call II Settings, can I assign them all to the same channel?
Station 1
Station 3
Fire Rescue 3
Fire Station 3
Station 7
Station 6
Station 12
Station 13
But my County Dispatches on OCFD 1.
Can I assign all these Tones to OCFD 1?????
Thanks Michael.
gtaman
TACSAT
GALAXY 19 91.0° W
Example:
Station 1
Station 3
Fire Rescue 3
Fire Station 3
Station 7
Station 6
Station 12
Station 13
Thanks Michael.
You can program all those sets to one channel. Also you can put them on other channels. But you cannot have more then one quick call II system per a channel. It's like mdc1200. You can have two mdc1200 systems on the same channel, only one is allowed. Try having a little fun and see what all you can do. Make sure you save a good codeplug if something goes wrong. but experiment and see what all you can do.
WA9TED
Milwaukee
You say "key up tone" Would you be referring to a talk permit tone? If so, you can't do it on a CP200, but side tone on an MDC preamble, you might be able to.
