How to program MARCS into a Pro-96
bigbluemsp
Michigan
I checked the pages and could only locate stuff for the Uniden scanners.
I want to add the I-75 corridoor to my Pro-96 as I make a lot of trips to Louisville/Lexington for employment testing and to visit family and friends.
I am using Win96 but how do I configure the setup in order to receive the MARCS system?
Bucko
Marietta, Ohio
I would setup a V Folder with the MARCS on your route on I75. I have several V Folders setup for when I travel I70 from Ohio to Illinois.
Below is an example of my local MARCS bank using a dummie freq between the CC's.
0 Marcs Mtta 867.07500 MOT
1 Marcs Mtta 868.67500 MOT
2 Marcs Mtta 868.93750 MOT
3 1300.00000 FM
4 Marcs Glass 866.17500 MOT
5 Marcs Glass 866.72500 MOT
6 Marcs Glass 867.56250 MOT
7 1300.00000 FM
8 Marcs Salem 854.98750 MOT
9 Marcs Salem 856.48750 MOT
10 Marcs Salem 867.41250 MOT
11 Marcs Salem 867.80000 MOT
12 1300.00000 FM
13 Marcs Newpor 855.48750 MOT
14 Marcs Newpor 868.06250 MOT
15 1300.00000 FM
16 Marcs L Hock 866.71250 MOT
17 Marcs L Hock 866.97500 MOT
18 Marcs L Hock 867.36250 MOT
19 1300.00000 FM
20 Marcs Cutler 866.67500 MOT
21 Marcs Cutler 866.95000 MOT
22 Marcs Cutler 867.21250 MOT
23 Marcs Cutler 867.93750 MOT
24 Marcs Cutler 868.95000 MOT
25 1300.00000 FM
26 Marcs Athens 866.63750 MOT
27 Marcs Athens 866.91250 MOT
28 Marcs Athens 868.88750 MOT
29 1300.00000 FM
30 Marcs Meigs 867.05000 MOT
31 Marcs Meigs 866.73750 MOT
32 1300.00000 FM
33 Marcs Morgan 857.73750 MOT
34 Marcs Morgan 858.71250 MOT
35 Marcs Morgan 868.31250 MOT
36 Marcs Morgan 868.96250 MOT
37 1300.00000 FM
38 Marcs Beverl 866.86250 MOT
39 Marcs Beverl 867.33750 MOT
40 Marcs Beverl 867.60000 MOT
41 Marcs Beverl 866.60000 MOT
42 1300.00000 FM
43 Marcs Noble 866.83750 MOT
44 Marcs Noble 867.16250 MOT
45 Marcs Noble 867.45000 MOT
You need to set the bank mode to MOT and RX mode to MOT, it should work fine as long as you have the correct freq entered.
Bucko
Marietta, Ohio
The dummie freqs seperate the Control channels so the 96 or 2096 will trunk the sites in that bank. Note that using 000.000 will not work, it has to be a valid freq.
radioscan
Radio Sensei
Butler County, Ohio
Here is my file for the I-75 Corridor in Ohio. I have many more Ohio interstate .p96 files in the files area of the Ohio_MARCS Yahoo Group.
radioscan
Radio Sensei
Butler County, Ohio
By the way I don't use dummie frequenicies between MARCS sites. I insert
actual frequencies that maybe used, mainly interoperable frequencies such as Intercity, LEERN and the NPSPAC frequencies.
For example:
.Dayton 03 868.60000
iCALL 866.01250
.Springfiel3 868.98750
iTAC-1 866.51250
.Greenville4 868.17500
iTAC-2 867.01250
.Sidney 04 868.78750
iTAC-3 867.51250
.Wilberforc1 868.96250
iTAC-4 868.01250
.Wilmington1 868.28750
Intercity 155.37000
.Lebanon 04 868.90000
LEERN F1 154.93500
.Loveland 01 867.06250
